ᐅ Radiator damaged just by leaning against it?
Created on: 23 Feb 2018 01:02
Schwabe007
First of all, I want to say that I’m not a homeowner, but I found this forum and thought it might be a good place to get some help. I hope you’re kind enough to assist me anyway.
My question might seem a bit silly or even trivial, but somehow I’m unsure.
So: I live in a small, recently renovated student room. The bathroom was redone as well, including all the fixtures and a new wall-mounted towel radiator. Today I took a shower and briefly leaned against the radiator, and I noticed a slight movement in it. I was a bit shocked and checked if everything was okay. Everything looks fine, except for two things. Picture 1 shows the top wall bracket, where there is a cap—or so I call it—that doesn’t seem to be properly seated, while on the other side it is correctly in place. But I can’t press it in any further; it’s quite firmly fixed.
And in picture 2, there are also caps that are simply loose. Is that normal? If it matters, the radiator is mounted on a drywall (plasterboard) wall, which also has tiles attached.
Could I have damaged something? Could it become dangerous if so? I know it might sound silly, but I’m quite anxious about it. Maybe someone here can help me.
Close-up of a white towel radiator with horizontal pipes under warm indoor lighting
Close-up of a wall connection with shut-off valve on a pipe in a plumbing installation
23 Feb 2018 22:36
Almost all the rosettes in our house are somewhat loose 😉 ... some can be tightened again. They only serve to cover up unsightly cuts or holes.
