ElGreco-15 Aug 2012 03:16I want to replace the old exterior basement wall insulation (5cm (2 inches) polystyrene) with thicker insulation. The masonry is easily accessible for me, so I can definitely do the work myself. I have already removed the old polystyrene, and the bitumen layer still looks very good. However, I want to apply a new coating. Can I simply paint over it, or is it better to remove the old bitumen first? If so, what is the best way to do that?
MODERATOR9 Aug 2012 21:08A second coating should not be a problem. You can inspect the old bitumen coating for any loose areas (which most likely will not be present). Simply scrape off any damaged spots.
However, check (technical data sheet, product information, application instructions) whether the product you intend to use for resealing is compatible with the existing coating.
