ᐅ Installing Vinyl Flooring in Narrow Spaces (Offset)
Created on: 19 Mar 2017 11:21
KlyX84
I want to cover a long, narrow room (1.40 m (5 feet) wide x 14 m (46 feet) long) with vinyl flooring. I have already purchased the vinyl, everything is fine.
However, it's generally recommended to install laminate/vinyl flooring in the direction of the sunlight. In my case, this would mean laying the planks across the width of the room. But the planks are about 1.2 m (4 feet) wide, while the room is 1.40 m (5 feet) wide. Considering the necessary 1 cm (0.4 inch) gap on each side, I would only have about 18 cm (7 inches) left for the piece from the second plank to create a staggered joint (a minimum of 30 cm (12 inches) is usually recommended).
My question: Should I really install the flooring this way with the short offset pieces? Or should I ignore the advice about the sunlight direction (there are many windows...) and lay the planks along the length instead? My concern then would be that the already narrow, corridor-like room might look even longer and narrower.
And if I cut the planks to get reasonable widths for the individual pieces, would that lead to a lot of waste or increased vinyl consumption?
But I’m sure you have some good tips for me.
KlyX
KlyX84
19 Mar 2017 20:16
I can accept a 4cm (1.6 inches) waste allowance. The proposal sounds reasonable and will likely be implemented on Tuesday... let’s see if I, an unskilled DIYer, can manage it.
Thanks in advance.
KlyX84
21 Mar 2017 09:22
Hi 11ant,
I didn’t calculate with centimeters but rather with percentages... rounded to the 120% you mentioned...
However, your approach sounds good, so I’ll have a look at it this evening. Phew, let’s see how it goes.
By the way, I live in Bavaria, but I have a secondary school diploma from Switzerland. That’s unfortunately a bit hard to compare with the Bavarian diploma. But I think I can just about accept the 4cm (1.6 inches) waste per row.
Thanks and best regards,
KlyX84
p.s. Oops, I see I already replied... Well, never mind.
