ᐅ How to retrofit a water pipe into a concrete wall and seal it properly?
Created on: 21 Sep 2023 19:54
Asprey
Asprey
21 Sep 2023 19:54
I have an old small concrete slurry pit. A hole was drilled in it some time ago to allow rainwater to drain out. However, I now want to collect the rainwater in the pit and install a tap in the existing hole so I can release the water when needed. How can I best seal the water pipe with the tap? Unfortunately, I haven't found a suitable solution yet, so maybe you can help me.
Patrick
WilderSueden
21 Sep 2023 20:58
So you basically want a plug? What about having an emergency overflow? You should have one anyway. And if you ever want to clean the pit, you can pump it out then.
Asprey
22 Sep 2023 10:22
Yes, basically a plug with a tap 😉. There is also already an emergency overflow.
