ᐅ The IKEA Malm bed creaks noticeably – what could be the causes?
Created on: 23 Aug 2021 07:42
Lisleo
I recently bought an IKEA Malm bed and noticed during assembly that it squeaks a lot as soon as you lie down on the mattress or move around. Does anyone have experience with this or know the specific causes? I suspect it could be related to the design of the slatted bed base or the connections between wood and metal, but I would appreciate any opinions or tips on how to fix it. Are there common weak points to check in order to reduce or eliminate the squeaking permanently?
BAUEVA schrieb:
You should systematically loosen one connection at a time (e.g., loosen a screw), check if the noise changes, and then tighten it again. Exactly! Although not intuitive at all, I did it this way and was able to identify the “culprits” 🙂
One more tip: placing a small piece of foam rubber or felt at critical points between the slatted frame and the bed frame—under the mattress and wooden parts—would be my secret weapon against annoying squeaking! 😉
With a bit of patience, the problem usually disappears.
