ᐅ IKEA BESTA – How do I repair a broken panel?
Created on: 9 Sep 2021 18:37
Lusuna
Hello everyone, I have a problem with my IKEA BESTÅ shelving unit. One of the shelves in the middle section suddenly broke—more precisely, the particleboard cracked completely in one spot. The board is about 16 mm thick (0.6 inches) and seems to have split due to a localized overload. I hope I don’t have to replace the entire board but can somehow repair it, also because I’m not sure if I can simply order a replacement panel from IKEA.
My specific questions are:
- What materials and tools are best suited to repair a broken particleboard like this?
- Are there proven techniques to make the shelf stable enough after repair to continue bearing weight?
- Do I need to reinforce it from behind, or is it sufficient to glue the broken area with wood glue?
Maybe someone has practical experience or even a guide on the best way to fix this kind of damage on a BESTÅ. Thanks in advance!
neoren
10 Sep 2021 08:41
Apply wood glue to the break and clamp for 24 hours.
Screw a strip from underneath to the shelf.
Don’t forget to pre-drill.
TANNAU
10 Sep 2021 09:03
If the chipboard is completely broken, the only solution is to remove it, glue it, clamp it, and then reinforce it securely from underneath with battens. This will ensure a longer-lasting fix.
Taubi
10 Sep 2021 13:29
In brief:
- Remove the panel
- Apply glue
- Clamp it
- Reinforce with wooden strips
This works well.
