ᐅ How to Connect an Outdoor Camera: LAN, Power Supply, or Battery?
Created on: 15 Aug 2020 20:15
C.beckmann1986
I have another question...
I am planning to install two LAN connections on the exterior wall of the new build to connect one camera each. However, the electrician is charging a hefty 500 euros net. This raises the question again: pay up and be happy, or look for an alternative.
Using LAN with PoE is, of course, the most convenient option.
With Wi-Fi, power is often needed there as well, which would also have to be installed. (Would a switch then be required? Because outdoor power typically needs to be equipped with a switch? The camera would be running 24/7, so the switch would basically be redundant.)
Battery (plus solar) alone feels a bit unstable in terms of reliability, etc.
Besides, I want to save my recordings on my own NAS rather than on some cloud service. That further limits the choice of cameras.
What would you recommend, also considering the cost? Can you also recommend a specific camera? Ideally, it should be compatible with Synology.
Thanks!
rick20187 Mar 2022 07:27
There is still a connection to your regular network. You need to be able to access it, including when you are away from home. However, it will be through only one port. The access then runs through the network recorder and is protected.
Take a look at Germanprotect or contact them. They can provide you with expert advice.
Bauenaberwie
7 Mar 2022 08:21
rick2018 schrieb:
There is still a connection to your regular network. You need to be able to access it, even remotely. However, it will only be through one port. The access is routed through the network recorder and is secured.
Take a look at Germanprotect or contact them. They can provide competent advice.
Perfect, yes I have seen the website. I will do that. Thanks again!
