ᐅ How much of the front door frame should be visible?
Created on: 18 Jan 2022 18:24
susanne556
Hello, we received our front door yesterday and unfortunately noticed that the top frame is only about 5mm (0.2 inches) visible. The side frame is about 3cm (1.2 inches). The overall appearance just doesn’t look right. The door supplier took the measurements and does not consider this a defect. Are there any guidelines for this?
I have attached a photo.
What are your thoughts?
Modern gray front door with vertical glass strip, horizontal metal strips in front of white brick wall.
seat8819 Jan 2022 05:56
All the worse if it was already finished beforehand.
schubert7919 Jan 2022 06:14
It really looks bad…. unfortunately, I can’t help you.
Hangman19 Jan 2022 10:39
Are front doors custom-made at all? In our case, there were three different widths of side panels that could be added on the left and/or right, as well as three door heights. While you could combine these options in various ways, it wasn’t possible to get a perfect fit to the exact centimeter (inch). Perhaps the door supplier simply chose the best possible option—but not a precisely custom-fit solution.
Tolentino19 Jan 2022 11:03
M.W. today the profiles are custom-made to size, just like window profiles. The person simply didn’t think it through or lacked a sense of aesthetics.
guckuck2
19 Jan 2022 17:14
Given the available width, a door with two sidelights simply does not fit. Not pointing this out during a consultation, in my opinion, shows incompetence or at least a lack of expertise… I don’t think there’s anything to gain from it.
