ᐅ How can the back panel of Billy bookcases be reinforced?
Created on: 19 Sep 2022 08:37
Adolf67
Good morning everyone,
I recently assembled several Billy bookcases from IKEA and noticed that the back panel on my models is relatively thin and tends to bend or come loose under heavier loads (e.g., with heavy books). My question is: What methods and materials are recommended to reinforce the back panel of Billy bookcases specifically, so it becomes more stable and the shelf remains durable and able to carry heavier weight?
I would appreciate tips that are easy to implement and preferably preserve the original character of the bookcase. Who has experience with a solid retrofit or knows effective solutions?
INGRID34
20 Sep 2022 08:16
I replaced the back panel of my Billy shelves with a 4 mm (0.16 inch) thick plywood board.
Although it is slightly thicker, it is straight and stable. You can attach it directly to the frame with small screws. Since then, I haven’t had any issues with warping or sagging.
V
Vinlen
21 Sep 2022 14:52
INGRID34 schrieb:
I replaced the back panel of my Billy shelves with a 4 mm (0.16 inch) thick multiplex plywood sheet
This is the best option when aiming for a permanently stable solution.
Additionally, it’s worth using well-sized plastic or rubber caps on the screw ends to protect the shelf where it contacts the wall or other furniture and to reduce vibrations.
A simple upgrade that further extends the lifespan.
NIKA61
21 Sep 2022 15:10
For minimal reinforcement, I recommend self-adhesive metal strips. They won’t work miracles, but they definitely help prevent sagging under moderate load.
