I am currently facing the challenge of securely mounting my IKEA Billy shelves on a drywall partition. Since the shelves will need to support a considerable amount of weight, I don’t want to use just standard shelf brackets—I am looking for a stable, long-term solution.
My drywall is a typical stud wall with a standard cavity behind the board (no OSB board or similar). Usually, there is insulation in between, meaning there is little to no solid substrate for regular wall plugs.
Does anyone have experience with the best way to securely fasten Billy shelves (standard size approximately 80 cm (31.5 inches) wide and 202 cm (79.5 inches) high) to such a wall? Which plugs or mounting brackets work best to prevent the shelf from tipping and to avoid screws pulling out?
Are there any special tips or materials I should consider? I look forward to your advice and thank you in advance!
Josefane schrieb:
For example, gluing small wooden panels behind the drywall or screwing them through the hole to reinforce the anchors.I also think that makes a lot of sense! If you have the option to access the back of the wall, you can really use that on a drywall to distribute the load effectively.
Sometimes you also see people installing cross battens on the inside. However, you should check whether this might compromise the insulation and structural integrity of the wall.
By the way, for those who prioritize maximum safety, you can always complement this with an additional floor anchor, provided the floor is not too sensitive.
This way, the wall mounting is relieved in case of heavy loads.
Good luck hanging your Billy shelves! 🍀
