ᐅ How do I repair stripped screw holes?
Created on: 31 Jan 2020 09:12
danfe35
Hello everyone, I have the following problem: in a wooden component, the screw holes have been stripped, meaning the wood around the screws is damaged so that the screws no longer hold. I want to continue using the component and am looking for a durable repair method to securely fix the screws again.
Which methods for repairing stripped screw holes do you know? I’m especially interested in tips for doing this at home with simple tools and materials, and which substances are best suited to ensure a stable hold. For example, I know that sometimes wooden dowels or special fillers are used, but I’m unsure which option actually provides the best connection and how to do it properly.
putan
1 Feb 2020 09:07
I can only agree with the advice given, but I’d like to add a practical tip:
Once you’ve glued the dowel and everything has dried well, you can coat the pre-drilled hole with a bit of wax (leftover candle wax works great). This prevents the screw from further damaging the hole and provides extra grip when screwing it in.
And don’t worry, with a bit of patience and the right pace, you’ll manage easily – every screwdriver has its moments of glory! 😉
Good luck, and feel free to share how it goes!
