ᐅ How do I repair scuff marks on Ikea Hemnes furniture?
Created on: 22 Jan 2021 08:17
Broder
Hello everyone, I have noticed wear marks on my Ikea Hemnes sideboard, especially along the edges and partly on the surfaces where dishes or other items are frequently placed. Since I really like this piece of furniture and don’t want to simply replace it, I’m wondering: What is the best way to repair these worn areas so that the surface looks uniform again and is protected for the long term? Which methods and materials are suitable for repairing small to medium wear on Hemnes furniture? I am particularly interested in the following points:
- Preparing the affected areas
- Suitable fillers or putties
- Color matching and surface protection (varnish, oil, wax)
- Tips for making the repair as inconspicuous as possible
I would appreciate concrete suggestions, including any personal experience or recommendations for commonly used products in such repairs. Thank you in advance!
O
onron
23 Jan 2021 12:29
Broder schrieb:
I would prefer not to change the characteristic of the Hemnes surface as much as possible.
Chalk paint tends to be more matte and absorbs moisture differently than lacquer. For a finish that closely resembles the original lacquer surface, I recommend a water-based acrylic lacquer that dries clear and remains flexible.
Furniture wax penetrates well but only offers surface protection and is more susceptible to scratches or water marks. Lacquer forms a protective layer that is more durable, especially on frequently used surfaces.
If the repair only involves a few small areas, wax can be a temporary solution, but for a long-lasting result, lacquer is advisable.
Ramon4
24 Jan 2021 08:03
Broder schrieb:
One more question: Do you think chalk paint changes the surface permanently, or does the typical lacquer appearance remain?
Chalk paint always has a somewhat velvety, matte surface, often referred to as a chalky finish. It is therefore different from the classic lacquer look and is unlikely to match the original finish of IKEA Hemnes furniture.
Broder schrieb:
Also: Is it enough to seal the spot with furniture wax after touching up, or should it definitely be a lacquer for better protection?
I recommend lacquer, especially for areas subject to abrasion, because the protective film is harder and keeps the furniture stable for longer. Wax may require reapplication and attracts dirt more easily.
For your project, a matte acrylic lacquer from a hardware store could be suitable, ideally matched to the rest of the furniture. I often use small bottles designed for model making or furniture restoration, which allow for precise application.
