ᐅ How do I repair broken edges on BILLY shelves?
Created on: 14 Mar 2021 07:43
goliren
Hello everyone, I have an issue with my Billy shelves – small pieces have broken off some of the edges, which affects both the appearance and stability. Specifically, it concerns the front edges of the shelves, which often have a thin veneer or coating. I would like to repair these edges without taking the entire shelf apart or replacing the shelves completely. Does anyone have a proven method for neatly fixing broken edges on BILLY shelves? What materials and tools are useful? Is there perhaps a trick to make the repair nearly invisible? I’d appreciate any advice, as I want the shelf to last a long time and look good.
Kolepau
16 Mar 2021 14:05
nera59 schrieb:
Slightly dampen abrasive paper – this prevents excessive wear and results in a smoother finish!
Great tip, thanks for sharing! I’ve never tried that before, but I’ll definitely give it a go next time :-)
A small additional suggestion from me: If you want not only to repair the edge but also improve its stability, you can glue a small strip (e.g., a thin wooden molding) underneath the damaged edge and then fill over it. This strengthens the edge and makes it less prone to further damage.
So, don’t get discouraged right away — with a bit of patience, everything will look great again! 🙂
Good luck!
