I’ve noticed an issue with my Billy shelf: the top edge on one side is unfortunately broken. It’s a slant that has damaged a piece of wood quite clearly – nothing that can be simply glued or filled, since the surface is chipped and the break partly affects the load-bearing edge.
I’m particularly interested in how to repair this sustainably and which materials or techniques work best for stability and appearance. I’d rather not replace the entire board but prefer to repair it precisely.
Has anyone had experience restoring an edge like this so that it is stable and looks reasonably good?
It’s important to me that the repair is not overly complicated or too expensive. Tips on suitable adhesives, fillers, or even sanding and refinishing would be appreciated.
Thanks in advance for your feedback!
Mathiasche27 Dec 2016 14:22Hello Anbogi,
to add a bit more to your question: I would check whether the damaged edge is only superficial or if the load-bearing capacity of the shelf is affected. If it’s the latter, you could also use a narrow wooden strip glued onto the broken edge to restore stability.
The choice of sandpaper also matters: start with medium grit (around 120–150) to even out any irregularities, then use finer sandpaper (220 or higher) for a smooth finish.
If you want to match the color tone, it’s advisable to use a suitable wood stain or varnish, as these don’t completely cover the wood grain but rather highlight it.
I hope this helps! Feel free to ask if you have any more questions.
