ᐅ How can I easily repair the sliding rollers on Ikea BESTA units myself?
Created on: 10 Dec 2022 08:42
jon67
Good morning everyone, I have a specific issue with the rollers on my Ikea Besta system. Some of the rollers stick or move much harder, making it difficult to pull out the drawers. I want to repair the rollers myself, ideally with minimal effort and without using any special tools. Has anyone had experience with the best and easiest way to fix the rollers on BESTA? What steps are necessary, what common problems should I watch out for, and how can wear and tear be prevented? I would appreciate detailed, easy-to-understand instructions or tips.
kieran
12 Dec 2022 08:13
gesar32 schrieb:
If the rollers are damaged, a complete replacement is recommended, as repairs rarely last permanently.
I agree with that. Replacement rollers from Ikea are generally very affordable and of sufficient quality, so replacing them is a better long-term solution. Also, installation can be done in a few minutes without much technical know-how.
When reinstalling, I recommend making sure the rollers fit precisely into the tracks and that the spring clips are fully engaged, otherwise they may jam again later.
Above all, you should check if the track itself is still in good condition, as this is often the actual cause of sticking or difficult sliding. Regular maintenance of the tracks with silicone oil also extends the lifespan of your rollers.
Charles
12 Dec 2022 12:07
Dilen schrieb:
The movement of the rollers should be smooth again afterwards – if not, check the ball bearings, which unfortunately are usually not repairable on Ikea rollers and should therefore be replaced.
I have had exactly the same experience. Many people think you can lubricate the bearings, but due to the design of the Besta rollers, this is almost impossible. I therefore recommend replacing the entire roller assembly. Removing them is easy with a flat screwdriver, and replacement rollers are available as spare parts.
In addition, you should clean the drawer slides to ensure the new rollers glide smoothly. Minor sticking points are often caused by dust and lint, which can easily be overlooked.
