ᐅ How do I clean and maintain Ikea PAX sliding doors?
Created on: 26 Dec 2020 09:23
Tilumeo
Hello community,
I have installed Ikea PAX sliding doors at home and would like to approach the cleaning and maintenance of these doors as professionally as possible. My question is: How do I properly clean and maintain Ikea PAX sliding doors without damaging the surfaces or the mechanical track system?
I am particularly interested in:
- Which cleaning products are suitable or should definitely be avoided?
- How should I clean the aluminum tracks?
- Are there specific care products for the door fronts (e.g., glass, melamine, or lacquer) and the running tracks that ensure long-lasting durability?
- Are the rollers or running tracks included in the maintenance, and if so, how?
I would appreciate it if you could share your experiences or tips. Thanks in advance!
JAMESONB41
27 Dec 2020 14:52
Disassembly is unnecessary if you regularly remove dust and hair. Use a vacuum cleaner with a narrow nozzle followed by a damp cloth. This prevents larger buildups and protects the mechanism. A more thorough cleaning every six months should be sufficient.
U
usbla
28 Dec 2020 10:28
Tilumeo schrieb:
How much effort is really involved in cleaning with disassembly?
The effort required to disassemble the tracks is moderate but does require some basic technical understanding and patience.
- First, the sliding door is lifted out of the upper running tracks and set aside.
- Then, the aluminum tracks can usually be pulled out easily.
- This allows individual dirt deposits to be removed more thoroughly without affecting the function.
I recommend performing this procedure once a year, depending on your living environment, to ensure smooth operation and prevent wear caused by dirt buildup.
Insufficient cleaning can otherwise lead to irreversible damage to the roller bearings and negatively impact the smoothness of movement.
