ᐅ How can you identify a faulty batch in Billy?
Created on: 16 Jul 2016 19:12
lenfe
Hello everyone, I have recently had more difficulties recognizing poor batches of Billy furniture before finalizing a purchase. My specific question is: How can you identify a poor batch of Billy? What typical signs, processing defects, or quality indicators should you check to make sure you don’t end up with a faulty or low-quality version? Are there certain production periods or serial numbers that tend to be more problematic? I look forward to your experiences and advice!
lenfe
17 Jul 2016 09:50
@ronAlberto
Thank you for your detailed explanation. So far, I haven’t focused on specific serial numbers, but I will pay attention to them on my next visit to the store. The information about production periods is very interesting – do you have a reliable source for determining the production date or interpreting the batch number? I’ve noticed that some floorboards in my furniture show slight warping – do you have any tips for accurately checking the load-bearing capacity? I want to avoid any sagging later on.
Juan31
17 Jul 2016 10:26
For batch identification, it is recommended to check the barcode or production codes printed on each package. These provide clues about the manufacturing date. The exact structure of the code is internal to IKEA, but the date can be roughly inferred. Another method is to measure the deflection under load: place a ruler or straight slat across the shelf board and test it by placing a defined weight (e.g., books) on it. A deflection of less than 2-3 millimeters (0.08-0.12 inches) is considered acceptable for this type of furniture. This should be tested before purchase, if possible.
lenfe
17 Jul 2016 13:41
Juan31 schrieb:
Another method is measuring deflection under load
Do you think it’s possible to do this at the store without upsetting the salesperson? And if so, what is the best way to proceed without causing too much inconvenience? I’d prefer not to cause any awkwardness, but of course, I want to make sure the quality is right.
kepunau
17 Jul 2016 14:07
Hi lenfe! 🙂 I would take it easy. Placing a few books or something on it shouldn’t be a problem. If you explain politely and kindly that you’re concerned about the quality, you usually won’t have any issues. You could say something like, “I just want to quickly check if this is stable enough before I make the purchase.” Sellers usually understand that well. Always with a smile, and it should work out fine 😉
NUGRANT
18 Jul 2016 09:08
This is brilliant, how you’re all working together here! I can only add: When you get a good batch, note down the serial number and document the differences, it helps later when comparing. And don’t forget: Sometimes a small defect is enough, but if you approach the supplier politely, it can often solve the issues. Keep at it – quality simply has to be right!!! :-)
ronAlberto
18 Jul 2016 11:32
lenfe schrieb:
I have noticed that some of the floors in my furniture show slight warping
Such warping often occurs due to moisture exposure or low-quality substrate panels. A less visible but critical sign is the creak test: under load, there should be no squeaking noises. Also, check the joints: loose screws or poorly fitting dowels indicate poor workmanship. If you send me the exact batch number, I may be able to provide more precise information about the production period and any known issues.
