ᐅ How can I quickly repair minor damages on the Pax myself?
Created on: 16 Aug 2020 13:07
syrus68
I recently treated my Pax vaporizer a bit roughly, which caused some minor scratches and superficial marks on the casing. Since the device is important to me in daily use, I want to repair these small damages myself as quickly as possible to prevent them from affecting the appearance too much or potentially causing further damage. My question is: How can I easily and effectively repair or hide small damages on a Pax vaporizer myself? Are there any special materials, household remedies, or tricks that have proven successful without damaging the device? I am especially referring to micro-scratches or small dents on the metal casing, not deeper defects.
Thank you in advance for any concrete tips and advice on the best way to proceed!
elgla
17 Aug 2020 14:55
Unfortunately, I have also noticed scratches on my Pax quite often and can fully understand your concerns.
Regarding the question about clear protective coatings: I once tried applying a very thin clear coat that is actually intended for metal surfaces. The application was fairly straightforward, but the surface ended up feeling slightly different—not as smooth anymore and appearing a bit more matte. This is a matter of personal preference, but it did improve scratch resistance.
In everyday use with frequent handling, such a layer lasts for about 3-4 months before it starts to peel off gradually – at that point, just reapply. It is important to clean the surface very thoroughly beforehand and apply the coating in a thin, even layer.
Also: If you are unsure, it is best to test first on an inconspicuous area to avoid any unintended side effects.
Traman4
18 Aug 2020 07:41
syrus68 schrieb:
I wonder how well clear coating paints work on metal housings to prevent or slightly reduce minor surface damage.
Clear lacquer can help, but it is not durable forever. If you need a quick solution, simple liquid films or thin protective films can at least provide basic protection. It becomes more complex if you want a perfect finish.
