Hello everyone, I own several IKEA Malm furniture pieces that have developed signs of wear and minor damage over the years, such as chipped edges, scratches, and occasionally loose screws. My goal is to professionally repair these pieces to preserve the original appearance as much as possible and ensure long-term stability. Therefore, I am interested in which steps and materials you would recommend for the best possible repair of Malm dressers or beds. Most importantly, I would like to know what types of adhesives or fillers should be used and how to restore the surfaces gently without noticeable color differences. Are there specific techniques to bring laminate or veneer surfaces back to good condition? Thank you very much for any helpful tips and experiences!
Leonardteo schrieb:
Repair kits from companies like "Color Expert" or "Molto" are recommendedThese brands are indeed the industry standard for furniture repairs, especially for laminate and melamine surfaces. Professional repair also involves preparing the area with a fine abrasive pad and then treating the surface with a special furniture polishing pad to match the gloss.
The success of the repair largely depends on the compatibility of the repair material with the specific melamine finish – it is advisable to conduct thorough research or consult with a specialist at a building supply store before purchasing.
Sinan-meo28 Sep 2021 18:39I would like to add that with Malm furniture, due to the particleboard construction inside, the stability of the connecting elements is often a critical issue. If screws are loose, it can help to reinforce the screw holes with wood glue and wooden dowels before re-screwing.
For the surface, I often recommend toothpick or stainless steel needle repair kits for small scratches, as they allow for authentic-looking repairs. If the damaged area is larger, the mentioned repair waxes and fillers are a practical solution.
