ᐅ How can I best arrange Billy-style shelving units in small alcoves?
Created on: 18 May 2023 17:43
RONPU5
I have a specific challenge with my IKEA Billy bookcases, concerning the optimal placement in small, rather unusually shaped recesses. These recesses are often narrow and limited in height, sometimes with irregular wall widths or slightly offset walls. My main question is: How can Billy bookcases be best positioned and possibly modified in such small recesses to make the most efficient use of the available space, without compromising stability or functionality? Are there proven methods, tips, or even recommended tools to adapt Billy bookcases for these kinds of spatial conditions?
I look forward to your experiences and advice, thank you!
Tinaneo
20 May 2023 08:24
The discussion seems to lack consideration of the materials involved and their weaknesses when making adjustments:
CARLA schrieb:
Planning adjustments: If necessary, slightly modify the shelf depth (typically 28cm (11 inches)) or the side panels using a fine file or sanding machine.
That sounds reasonable, but: What material is the Billy shelf made of? Particleboard or MDF panels, usually laminated. Simply sanding could damage the surface structure and lead to faster material degradation, especially at the edges.
Therefore, my question is: Are there any experiences regarding the long-term durability after such modifications? Or would it be better to consider other options, such as identical shelves with the right dimensions?
If user RONPU5 posts the exact measurements of the niche, it would be possible to recommend suitable alternative models.
