ᐅ How can I install Malm furniture without any vibrations or movement?
Created on: 15 Feb 2020 18:43
teoje60
I plan to assemble a Malm furniture piece from Ikea that has always had an issue in my apartment with so-called vibration pulsations—small, unpleasant vibrations or slight movements that make the furniture appear unstable. My main question is: What specific steps or measures do you recommend to assemble Malm furniture so that it is free of pulsations and stable? I am interested both in the situation on uneven floors and possible improvements in connecting the individual parts to completely eliminate vibrations. Which mistakes should I definitely avoid, and are there any tips for tools or materials I could use in addition to the Ikea parts? I would appreciate any advice to ensure the furniture stands completely steady in the end.
Best regards!
Mariah
17 Feb 2020 09:03
teoje60 schrieb:
Also, I’m considering replacing the usual felt pads with a better option because they tend to slip.
I agree with that! Felt pads are soft and protect the floor, but they can wobble if they’re not properly glued. I’ve often used small silicone pads on my Malm dressers; they hold firmly and absorb vibrations quite well. They come in various sizes and are usually self-adhesive.
They’re easy to apply and hardly visible. In a way, they’re the little heroes for vibration-free furniture!
Try a bit of experimenting—maybe a combination of a soft pad plus properly adjusted screws—and you should be on the safe side.
