ᐅ How can BILLY doors be made easier to open and quieter?
Created on: 4 Oct 2024 18:03
Annette42
I am looking for ways to make the doors of the IKEA Billy cabinet operate more smoothly and, above all, more quietly. The lock or hinges are not faulty, but the doors are a bit stiff and creak loudly when closing, which is quite disturbing, especially at night.
I suspect that the issue is not only mechanical but involves the entire closing process, including the guides and stops. I wonder if there are effective modifications that can be done easily by oneself—such as dampers, material changes, or lubricants.
Has anyone experienced similar problems? Which solutions really improve ease of movement and reduce noise? I am particularly interested in the types of hinges or dampers that work best with BILLY without affecting its appearance and function.
I would appreciate any helpful tips or warnings about potential pitfalls when retrofitting!
PeoDaniel
6 Oct 2024 08:13
Annette42 schrieb:
Has anyone here had experience with similar issues?
Yes, I encountered this problem myself and combined several steps to resolve it. First, I carefully readjusted the hinges using an appropriate screwdriver, which already helped reduce the tension on the door leaf.
Next, I applied silicone spray – it’s important that the surface is clean and dry beforehand. After that, I attached small soft felt strips to the door stop points. This significantly cushions the impact.
If you prioritize silent closing, you can also install universal soft-close dampers. Be sure to take precise measurements and follow the installation instructions, as BILLY is not specifically designed for this.
If you’d like, I can gladly provide you with a step-by-step guide on how I went about it.
