I plan to store several very heavy boxes (about 25-30 kg (55-66 lbs) per box) in the IKEA KALLAX shelving unit. My question is: What is the best way to safely secure such heavy boxes or crates in the KALLAX so that they stand firmly, do not slip, and the shelving itself does not get damaged?
I am especially interested in which methods or additional aids you use to prevent the boxes from tipping over or shifting sideways. Tips for custom-built solutions or modifications for the KALLAX would also be very helpful.
I look forward to your experiences and advice!
Shawn38 schrieb:
Before securing the boxes, you should check how much weight the shelf can actually support\Thank you very much for the detailed tips! I did underestimate the weight, and it’s good to know that the load capacity is so low.
I plan to keep the boxes there long-term, so they won’t be pulled out often, but they absolutely need to be secure and stable.
NUGRANT schrieb:
wide hook-and-loop straps attached to the cabinet – holds great and opens quickly\I like the idea of using hook-and-loop straps because I also need the option to quickly remove the boxes when needed.
I will definitely get some anti-slip mats and also secure the shelf to the wall.
pinbo schrieb:
It’s not just a question of how to secure the boxes, but whether the shelf can handle the load over time\You’re right, I will reinforce the shelf board with a plywood panel beforehand.
If anyone has specific recommendations on the best thickness and material, I would appreciate it! Thanks to everyone so far for the great advice :-)
