ᐅ Heat Pump Foundation Too Close to Garage: Repair or New Construction?
Created on: 19 Jun 2018 22:48
Snowside
Our site manager knowingly allowed the foundation for the external unit of the air source heat pump to be poured with only an 11 cm (4.3 inches) gap from the future garage wall. The air source heat pump’s manual states that there should be at least 20 cm (7.9 inches) clearance.
Now the plumbing specialist has already noticed that it is very close to the garage foundation and has positioned the external unit as far towards the end of the heat pump foundation as possible, to leave as much space as possible. (I assume he didn’t know that the garage extends 30 cm (11.8 inches) beyond the garage foundation on each side.) However, one corner of the heat pump foundation broke off during this process.
In any case, the site manager believes he can repair the break and simply extend the heat pump foundation by 20 cm (7.9 inches), thus achieving just over the required minimum clearance.
Is it possible to repair the break without any issues and extend the heat pump foundation, or is this a substandard, cheap fix? I definitely do not want the foundation to crumble during the next frost. Should I insist on a new foundation?
Thanks for your help.
Snowside
Outdoor condenser of a heating/air conditioning system installed on building ground in front of the house wall
Large concrete foundation with mounted metal posts on a construction site and gravel around it.
Caspar2020
21 Jun 2018 21:00
No; a competent site manager would have secured the rail with adhesive putty. Screws are overrated.
HilfeHilfe
21 Jun 2018 21:01
Does it cost that much to pour a new concrete foundation? It’s definitely not 15,000€. But you do have a poor-quality builder.
markus270325 Jun 2018 11:05
I can't contribute much to the topic, but in my opinion, the corner of your house in picture 1 also looks a bit "unusual."
Is that really correct? The corner seems to be hanging in the air...
Snowside
25 Jun 2018 18:04
markus2703 schrieb:
I have nothing to add on the topic, but in my opinion, the corner of your house in picture 1 also looks a bit "odd."
Is that really correct? The corner seems to be hanging in mid-air...
I believe that is correct. All the walls are resting on the foundation, and then the thermal insulation was glued and screwed on. That’s why it looks like the corner is floating. The area around it will be filled with soil later.
markus270325 Jun 2018 18:23
Okay, then I misunderstood. I thought the wall was hanging in mid-air there. With the external thermal insulation composite system (ETICS), it’s not as problematic.
