ᐅ Green Roof on Flat Roofs: Managing External Drainage Outlets
Created on: 11 Aug 2020 13:39
kwakz1984
I am currently building my own home with a flat roof. It needs to be greened, which I would like to do myself. Most things are clear to me, but I still need some advice on one point: How should I deal with our external drainage (the spot where a pipe passes through the parapet)? I probably shouldn’t put gravel directly in front of it. But should I simply leave a gap in the gravel, or would it be better to install a barrier made from L-profiles?
I hope I was able to explain my concern clearly enough.
Daniel
Daniel
Müllerin schrieb:
In our neighborhood, there are two houses with green pitched roofs. They look great. The slope... well, definitely less than 45° (45 degrees). Sure, no question it’s possible. The question was whether the effort is greater: it is, and a green roof carries more risk of leaks. Everything else is a matter of perspective. Green roofs = environmentally friendly, expensive, and riskier! With pitched roofs – which is why I phrased it carefully earlier – the effort is significantly higher because the roof structure is completely different and more complex.
