ᐅ Old farmhouse, insulation damaged—how to repair it correctly?
Created on: 26 Oct 2008 09:49
Leeloo-1
26 Oct 2008 09:49
Yes, I'm back again with my never-ending construction project: the farmhouse!
Now the following problem has come up. While removing the wallpaper, some underlying surfaces were revealed that I hadn’t even dared to think about before. In one corner, there is now a hole about half a meter (1.6 feet) in diameter and approximately 3 cm (1.2 inches) deep, exposing what looks like a clay/straw mixture. Can someone give me advice on how to repair this disaster?
ferdi-1
27 Oct 2008 12:38
So, when I imagine it the way you describe, the first thing that comes to mind is a complete renovation! 😉
Alternatively, you could fully cover the wall with drywall panels. Another option would be using mesh material, either as a mat or what some call plaster mesh. This can be useful in many cases, although drywall panels would be more professional and durable in the long run.
Anhang-1
14 Nov 2008 18:34
In this case, you will need to find a craftsman who is experienced with these techniques. If you simply cover it up with gypsum plaster, it might no longer hold properly. You have to be careful with old building materials because they are often not compatible with modern materials. You can only repair them using the same type of material!
schwarzmeier-1
7 Jan 2009 18:26
Plaster Damage
Clean the substrate from all loose and non-bearing parts and repair with matching clay plaster. 😀
