ᐅ Experiences with Central Vacuum Systems Featuring Built-in Wall Hose Inlets
Created on: 15 Jan 2016 11:07
SirSydom
SirSydom
15 Jan 2016 11:07
I saw that there is a system called "Hide-a-Hose," where the long hose is completely hidden inside the wall.
Who of you has experience with this and can share insights from daily use?
- How well does the hose retract?
- Is it possible to use the hose without fully extending it?
- Does the hose get dirty on the outside? Since it is pulled back into the pipe...
bauherr48
3 Mar 2016 15:39
Hello, this system works perfectly. It is important to use the specially designed "long" bends. Also, the suction pipe must be 2" (50 mm) in diameter (not 50 mm pipe). You only pull the hose out as far as you need it. The instructions for pipe installation must be carefully followed! Since no dirt settles on the pipes, the hose inside the pipe will not get dirty either.
If you need more information, please let me know.
SabrinaSch.
24 Jul 2017 08:58
Hello.
We are currently planning our house as well, and I would like to have a system with wall entry. Can you recommend a supplier for that? I have already been in contact with someone who marked the pipe routing on the floor plan for me, but they do not offer a system with hose entry, and I find that much more convenient than carrying a hose over my shoulder. My husband is a bit apprehensive about the installation, which we would be doing ourselves.
bauherr48
24 Jul 2017 14:40
Hello SabrinaSch.
This system is very simple. You can request an installation proposal and a cost estimate from Info@saugsysteme.com. You can also get informational materials there. The installation is very straightforward. An installation manual is also available.
