ᐅ Expansion joint between two terraced houses – responsibility according to DIN standard?
Created on: 11 Aug 2021 11:14
Chris1110
We have a single terraced middle house, which has recently had an extension added. The exterior wall facing the neighbor is made of calcium silicate brick, probably 17.5 cm (7 inches) thick, and is unplastered.
The neighbor has attached a prefabricated timber frame extension. Now there is an approximately 5 cm (2 inches) wide gap between our houses. According to my builder, the party adding the extension is responsible for sealing this gap.
From what I understand, this should be sealed by inserting mineral wool strips and/or compressible sealing tape along with a mounting rail. Additionally, a metalworker should install a flashing extension at the roof junction to prevent water ingress between the houses.
My neighbor seems unaware of this and claims their building is designed as a "detached house," even though their timber stud wall facing my property also has open joints where moisture could enter.
Is there any specific standard (e.g., a DIN norm) or regulation that clearly states the responsibility lies with the party building the extension?
I am concerned about the upcoming winter if the neighbor does not take action. Also, I wonder whether compressible tape and the mounting rail alone are sufficient, considering the potential for thermal bridging... I am willing to insert the mineral wool strips myself if necessary, but I am not prepared to cover the costs for the rest.
Chris1110 schrieb:
... we have a single middle terraced house, to which an extension has now been added built, ...
The neighbor has added a prefabricated timber frame extension built.
There is now an approximately 5 cm (2 inch) wide gap open between our houses.... Rarely has @11ant been so right ... (well, he often is, but this fits really well here)
Sorry, wasn’t it noticed that the damage is already done? Almost everything has already happened.
The appropriate (sound insulation) insulation material can no longer be installed between the houses 🤨
What kind of cladding (plaster/brick/wood) does the neighbor’s timber house have? Wood fiber insulation boards, for example, are usually rated for exposure to weather for up to 6 months, after which the manufacturer’s warranty expires.
The neighbor should make sure the issue is properly resolved from a technical point of view before the start of the 2021/22 winter season. Otherwise, I see a bleak outlook for them, and a “only” gray one for you.
i_b_n_a_n schrieb:
The appropriate (soundproofing) insulation material can no longer be installed between the houses anyway.I actually see that somewhat positively – at least it can't have the opposite effect then.https://www.instagram.com/11antgmxde/
