ᐅ Lightweight expanded clay aggregate (LECA): Advantages and Disadvantages, Thickness, Suppliers
Created on: 17 Jan 2023 10:29
Mar_Mar
Good morning everyone!
My husband and I (both rather paper people) are planning to build a fairly large semi-detached house and are navigating through the jungle of options. We want a solid construction and have spoken with various suppliers. The available options regarding blocks are aerated concrete, Poroton, and expanded clay (prefabricated), all 36.5cm (14.4 inches) thick and built as monolithic walls. Of course, each consultant believes their own material is the best, so I would be interested in your opinions and experiences.
“Actually,” we would rather not build with aerated concrete/Ytong because our naive assumption about moisture absorption (sponge effect) during construction and later when drying out the house seems negative. However, I can understand the argument for its easy workability.
Poroton would be our “favorite,” but I get the impression that many companies really resist using it because of a lot of waste, losses during transport, and comments like “you don’t notice a difference,” etc. Then there is also the split between filled and unfilled blocks.
And then there is expanded clay. Our “new favorite with a question mark.” It seems very interesting because it somehow combines the best of both worlds: dry straight from the factory, quick, even cheaper. BUT if it’s so good, why don’t more people build with it and why are there relatively few suppliers? That makes us skeptical. I’ve read and researched a lot that it often cracks and that its insulation properties are not the best compared to Poroton. We were told that an unfilled 36.5cm (14.4 inches) Poroton block is comparable in properties to a 42cm (16.5 inches) expanded clay block.
We are lost in this jungle of U-values, lambda, etc. Can you support us?
By the way: insulation is more important to us than soundproofing.
Thanks so much!
11ant9 Jan 2024 13:08
Bobby007 schrieb:
And did you have any negative experiences with sound insulation?
I am a satisfied resident of a multi-family building.
Mötelly schrieb:
That is really good advice about local building experts. It is true that many providers seem very friendly at first, but in the end you invest more time, effort, and money.
What exactly are you referring to in your post?
