Good morning everyone,
I am currently considering adding extra inserts to my IKEA KALLAX shelf unit, which I plan to install myself. My question is: how risky is it to drill into the KALLAX shelf to attach additional inserts or brackets?
My main concern is whether drilling could compromise the stability or material structure to the point where the shelf might be damaged or even break later on.
Has anyone had experience with this, such as the best approach to take, which tools should be used, and if there are specific areas on the KALLAX that should never be drilled?
I look forward to your opinions and advice!
When drilling into KALLAX: always use a drill bit intended for wood, and do not drill too quickly. Holes should be no closer than 10-15 mm (0.4-0.6 inches) from the edges, preferably further in. Test on a sample board beforehand. Use screws with wide washers.
This helps maintain stability.
