Q
Quickborner15 Feb 2023 22:11Hello!
We will be paving our terrace above the base layer, so it won’t be at ground level. Would you still recommend installing a drainage channel beneath the base layer?
If yes, would a simple infiltration system using a corrugated pipe with gravel be sufficient, or should it be connected to the main sewer system?
Thanks for your help.
WilderSueden16 Feb 2023 00:02As long as you are deep enough below the threshold so that no standing water pushes through the patio door and you have a slope away from the house, I would skip the gutter.
