ᐅ Double wire mesh fence – privacy slats possible. What about wind load?
Created on: 6 Jun 2024 10:51
Gretel1990
I have the following question:
We want to attach privacy slats (3 horizontal rows) to our welded wire mesh fence. The fence panels measure 1.60 x 2.50 meters (5.25 x 8.2 feet) each and are mounted on concrete.
Photos attached to show the surrounding buildings. There is a distance of 22 meters (72 feet) between the fence and an outbuilding. This is a residential area in southern Brandenburg.
Will the fence withstand the wind load if we install three standard privacy slats over about 7 panels? Or would it be better to use “wind-permeable” privacy slats?
Garden with green lawn, small gray building, trampoline on the right, houses in the background.
Garden with green lawn, paved path on the left, pergola with flowers, fence in the background
6 Jun 2024 22:17
A fence should be able to blend into the background when it’s not really needed. Why anyone feels the need for privacy screening here, you’ll have to explain to me, @Gretel1990
Coletrickle_7808 schrieb:
It will hold up...
I disagree. Our worksite building is partially fenced with privacy slats at a height of 180 cm (6 feet). After three years, the edges are quite worn out. There are gaps at the posts, some frayed edges, and we constantly have to fix slats that have come loose due to the wind.
By the way: they are terrible. Even worse with photo prints. The photo you have in real life needs no additional decoration.
