ᐅ Does a snow and ice load gutter require a heat trace (heating cable)?
Created on: 19 Jan 2021 19:51
lesmue79
lesmue79
19 Jan 2021 19:51
Looking at the current snow loads on our zinc gutter, I’m wondering how much snow or frozen snow it can actually support?
At the same time, due to the freezing temperatures over the past few days, snow and ice are building up in the gutters, and hardly any snow slides off the roof. Does an electric heating cable, which you place inside the gutter and turn on as needed, help in this situation? So that the snow melts gradually and slides down into the gutters? Or does this just end up benefiting the electricity provider because you’re effectively heating the outdoor air?
Tassimat
19 Jan 2021 20:02
Sorry, but I can only call that an absolutely crazy idea 😀
Have the gutter properly reattached if it has come loose.
By the way: How many fallen gutters have you actually seen when walking down the streets?
lesmue79
19 Jan 2021 20:06
First of all, nothing has fallen off, bent, or anything like that, and it’s definitely not giving that impression.
As a new homeowner, you just naturally have some concerns.
But it’s good that for you it seems like a crazy idea, although those things probably do have some valid purpose.
WilderSueden
19 Jan 2021 20:30
Ideally, when building, snow guards should be installed to prevent snow from sliding off the entire roof into the gutter or falling on someone below. Snow rails are relatively inexpensive if installed during the initial construction but significantly more expensive to retrofit later.
I also consider heating elements for the gutter to be rather unnecessary. The gutter should be sized according to the snow load zone; for mountainous areas, there are also specially reinforced gutters available.
haydee
19 Jan 2021 20:34
Break off long icicles. They can be quite heavy.
Snow guards or snow stops are recommended. This way, you won’t have to worry much about anyone being hit by falling snow from the roof.
lesmue79
19 Jan 2021 21:55
Snow guards are installed above the entrance but not around the entire house.
It was just an idea regarding the gutter heating.
