ᐅ Do not plaster any rooms in the attic.
Created on: 16 Mar 2017 11:37
jan2110
A small room was converted in the attic above our bedroom.
The rafters are insulated with loose-fill cellulose insulation. The other part of the attic is separated by a wall, and there the ceiling of the upper floor is insulated.
On the partition wall and on the sloped ceiling, drywall panels (plasterboard) have been screwed in and filled.
Now the window has been replaced, and I want to focus on the gable wall.
I first roughly removed the old plaster around the window and primed the surface.
Now I am considering which plaster to use.
Rotband (a gypsum plaster) or something lime-based? The room will later be used as a bedroom. The wall area is about 8 sqm (86 sq ft).
I don’t want to use drywall panels again, as I would like to try plastering a wall myself.
The wall and the roof were and still are dry.
Normally, a gypsum plaster should be sufficient, right? I’m just a bit concerned about condensation possibly forming on the walls since the window is now completely sealed.
Air can only circulate downward.
To sum up:
- Converted attic
- Bedroom
- Gable wall
- Gypsum plaster (Rotband) or lime-cement plaster?
P.S. Is it normal that the bricks on the gable are laid in a random pattern? With my limited plastering skills, I have quite a job to level the wall and make it straight.
Jan
jan2110
17 Mar 2017 16:03
I have already watched the video once. They use a surface filler there. I have now obtained bonding plaster. I want to use it to smooth out the wall.
However, my craters are somewhat larger than the ones in the video.
