ᐅ Are digital thermostats for underfloor heating worthwhile? Is the additional cost justified?
Created on: 3 Mar 2018 21:56
schmidt1904
Is it worth paying extra for digital thermostats in a new build with underfloor heating, in terms of more precise temperature control?
I am currently adjusting all rooms using the thermostatic radiator valves since we don’t have an energy recovery ventilator (we didn’t want one). Once that is done, you rarely need to change anything, right? But when I read here that some are running 25-26 degrees Celsius (77-79°F) in the bathroom, that seems really crazy to me??? We have just under 23°C (73°F).
Knallkörper7 Mar 2018 07:07In the children's rooms, we actively control the temperature using the RTRs. On weekends, the temperature is turned up, and on the other days, it is turned down. This has nothing to do with saving energy, but the children sleep much better below 20°C (68°F) – and so do I – and the children basically only play in their rooms on weekends. I have been used to higher temperatures in the bathroom for some time now and find it very comfortable.
In the living room, I can't regulate the temperature through the radiator valve (HKV). The required heat output is very low on the ground floor on the southwest side, and the flow temperature in the system is quite high. As a result, the RTR switches on and off frequently there. When the sun is shining, it is always “off,” so I can hardly do without it here.
Knallkörper7 Mar 2018 07:22bortel schrieb:
The result is that many other radiators have to be throttled --> heating cycles on and off.I'm never entirely sure what exactly is meant by "cycling," but you're probably right. However, it doesn't bother me since that's what the controllers and actuators are designed for.
