ᐅ Creating an Opening in a Load-Bearing Wall Without a Structural Engineer?
Created on: 27 May 2026 07:34
Lory2210
Lory2210
27 May 2026 07:34
I would like to add a second doorway in a load-bearing wall that is about 4.5m (15 feet) long. The new opening would be approximately 2m (6.5 feet) away from the existing one. Does the second opening need a structural calculation, or would an opening 70-80cm (28-31 inches) wide and 2m (6.5 feet) high be possible without any issues if I install a steel beam above it?
Thank you very much for your help and best regards!
Simon-189
27 May 2026 08:31
The opening is not a problem if the steel beam, along with the type and size of the bearing pad, has been structurally engineered.
Without structural calculation, do not attempt it.
MachsSelbst
27 May 2026 09:02
Lory2210 schrieb:
Does the second opening need a structural calculation, or would an opening about 70-80cm (28-31 inches) wide and 2m (6 ft 7 in) high be possible without issues if I install a steel beam above it?
No, just do it. Take any steel beam that looks big enough and put it in there, what could possibly go wrong...
Now seriously:
If you’re asking a question like this, you should leave it to a structural engineer because it has to be done properly. Otherwise, even the best structural calculation won’t help you.
Grundaus
27 May 2026 10:10
Any experienced mason should be able to assess this without a structural engineer; if there are concerns, simply use a thicker beam.
MachsSelbst
27 May 2026 13:48
True. He can also take care of the demolition work if things go wrong.
