ᐅ Soil Investigation Report
Created on: 16 Jun 2015 16:43
laemat
laemat
16 Jun 2015 16:43
today we received the results of the soil investigation.
I see two values: 1.15 - 0.45 m (3.8 - 1.5 ft) and the note stating a minimum proof of frost resistance of 1 m (3.3 ft). Does this mean that at least one meter will be excavated, or is only the bearing layer scraped off, i.e. one corner is 1.15 m (3.8 ft) deep, otherwise only up to 0.45 m (1.5 ft)? Or are these completely different values?
Note: S2 is a building corner
Thank you
P.S. Sorry for the quality, the forum did not accept the large PDF
Lumpi_LE
17 Jun 2015 08:23
One thing is not directly related to the other. The fill layer, which is between 1.15 and 0.45 meters (3.8 and 1.5 feet) thick, must be removed – it is not suitable for foundation support.
Regardless, in your case, the ground must be frost-protected to a depth of 1 meter (3.3 feet). There are various options for this, which the project planner can explain to you.
