ᐅ Reinforced concrete staircase height difference adjustment
Created on: 27 Sep 2016 08:48
Makita
Makita
27 Sep 2016 08:48
we now have our first “small” problem on the construction site.
Our reinforced concrete staircase has a higher first step and a lower last step, so it basically fits.
Now to our problem: the height does not match the floor buildup. With the finish, it will be about 18cm (7 inches) instead of the planned 17cm (7 inches).
First step about 28cm (11 inches)
All others 18cm (7 inches)
Last step 8cm (3 inches) (flush with the base slab)
Top step height (created by screed and floor buildup) 18cm (7 inches)
The stairs are supposed to be covered with wood (28mm (1 inch)).
The screed installer is coming today, and we will look for a solution then, but I would like to get some advice in advance on how to solve this issue.
Either I am missing something, or no matter the buildup, I can’t achieve a consistent stair rise height of 19cm (7.5 inches):
Example calculation (19cm (7.5 inches) finished rise height):
First step: 28cm (11 inches) - 18cm (7 inches) finished floor = 10cm (4 inches) + stair tread 3cm (1 inch) = 13cm (5 inches) - target 19cm (7.5 inches) = -6cm (-2.5 inches)
1st step: 18cm (7 inches) - 6cm (2.5 inches) increase of first step = 12cm (5 inches) + 3cm (1 inch) stair covering = 15cm (6 inches) - target 19cm (7.5 inches) = -4cm (-1.5 inches)
2nd step: 18cm (7 inches) - 4cm (1.5 inches) increase from 1st step = 14cm (6 inches) + 3cm (1 inch) stair covering = 17cm (7 inches) - target 19cm (7.5 inches) = -2cm (-0.5 inches)
3rd step: 18cm (7 inches) - 2cm (0.75 inches) increase from 2nd step = 16cm (6 inches) + 3cm (1 inch) stair covering = 19cm (7.5 inches)
4th step: 18cm (7 inches) - 0cm = 18cm (7 inches) + 3cm (1 inch) stair covering = 21cm (8 inches) - 19cm (7.5 inches) target = +2cm (0.75 inches) (I would rather avoid grinding the stairs)
Can anyone help me here?
Florian
tekci.mustafa27 Sep 2016 08:56
I’ll join in here. We have the same problem.
Legurit
27 Sep 2016 11:13
A cross-sectional drawing or sketch would be helpful. Additionally, floor plans of the entry and exit areas.
Makita
27 Sep 2016 12:14
I quickly sketched something; maybe it helps. Otherwise, I’ll have to wait until this evening to provide more precise measurements.
Thank you.
Florian
Konstruktionszeichnung des Bodenaufbaus mit Dämmung, Estrich und Bodenplatte
2D-Grundrissplan mit rechteckigen Räumen, zentrale Treppe, blau markierte Tür
Bieber0815
27 Sep 2016 22:31
Is there a cross-section drawing from the architect? (Preliminary design or detailed design?)
As your sketch is, it somehow doesn’t work ... *pondering*
Makita
28 Sep 2016 09:07
The problem is solved; the work was not done properly, but it is no problem to fix. All steps will be raised by 8cm (3 inches). The remaining difference of 9.5cm (4 inches) will be distributed across the 17 steps. This results in a finished riser height of 18.5cm (7 inches) instead of 18cm (7 inches).
