ᐅ Steel shelving unit with reinforced edges – how to implement?
Created on: 29 Oct 2021 19:27
francis34
I am planning to reinforce the edges of my Billy shelving unit because I intend to store somewhat heavier items and want to ensure that the shelves do not sag over time. My idea is to somehow strengthen the edges, either with additional battens, metal brackets, or another practical solution. My main questions are:
- Which materials and methods are best suited to reinforce the edges of the shelves without affecting the appearance too much?
- What is the best way to install the reinforcements so that they are stable, precisely measured, and neatly fitted?
- Does anyone have experience or advice on what to watch out for to ensure the shelves remain solid and safe after modification?
I appreciate any tips, instructions, or warnings about potential pitfalls. Thanks in advance!
francis3431 Oct 2021 14:07Jensson schrieb:
Mistakes I've seen: Not pre-drilling enough – this can cause the wood to split.This is a very important point, thanks! I underestimated that in my last small project.
RENMA schrieb:
Assembly is done after precise cutting using high-quality wood glue (at least D4 class) and additional fixing with screws, with pre-drilling to avoid splintering.Can anyone give specific recommendations on the optimal screw length and thickness here? I want to avoid the screws coming through the shelves or being visible on the front side as much as possible.
Joe52 schrieb:
I would recommend reinforcing the edges with some kind of metal U-profile; that usually holds best and provides good stability.How noticeable are these metal profiles approximately? I ask for aesthetic reasons.
Thanks to everyone for the helpful advice so far!
