Thentrue schrieb:
Can someone explain what is happening to our basement wall? It seems to be damp from the bottom. The moisture is rising upwards.
Thentrue schrieb:
What should be done to fix the problem? You need to find the cause of it.
Thentrue schrieb:
There is an entrance staircase on the outside. Then show the outside corner. Usually, a sump has formed there because the drain is clogged due to lack of maintenance.
