Does anyone happen to have experience with multiple zones on an Automower? The problem is that I have two separate lawn areas. They are divided by a path made of 1 x 1 meter (3 x 3 feet) concrete slabs. The slabs are framed by steel sheets that are set in concrete. I can route cables between the two areas through empty conduits, but I can’t lay the boundary wire close to the surface continuously through that route. Am I missing something, or what options do I have to manage this without using GPS?
I am currently running a 405 X. I have two zones. The second zone is marked off with the boundary wire. I then place the robot in the second zone and let it run there for about 30 minutes. After that, it switches off and waits to be moved back to the main zone. This works perfectly.
