ᐅ Installing Ikea Metod Kitchen Cabinets Precisely Under Sloped Ceilings
Created on: 10 Nov 2016 08:37
V
valdemar31
I am currently planning to install my Ikea Metod kitchen in a room with a sloped ceiling. My main question is how to precisely fit the Metod kitchen cabinets to a sloped ceiling, especially when it comes to the wall cabinets. The slopes are quite steep, so standard heights and widths don’t simply fit without adjustment.
I am particularly interested in which modifications or cuttings are best suited to adapt the cabinets optimally and without large gaps to the slope. Are there proven methods for creating angled panels or trims, or special installation tips that are useful for Metod cabinets?
Also: how can the cabinets be securely mounted if the wall below the slope is not perfectly vertical?
I look forward to your experiences and advice—particularly if anyone has already installed an Ikea Metod kitchen in an attic or loft space with a sloped ceiling.
Gerard
12 Nov 2016 19:05
valdemar31 schrieb:
Do you have a recommendation for the ideal thickness of this supporting battens so that they are stable enough without taking up too much space?
Commonly used battens are made of solid wood, typically spruce or pine, with a thickness between 18 and 24 millimeters (around ¾ to 1 inch), depending on the load of the cabinets. This thickness is thin enough to minimize depth loss while still providing sufficient stability. It is important to install the battens horizontally and secure them flush to the wall with dowels.
valdemar31 schrieb:
Whether I should make the panels myself from wood boards or if there is an easier solution for adjusting the Ikea-specific parts
Unfortunately, Ikea does not offer specially prefabricated angled panels. The Metod panels are straight. Therefore, cutting custom-made panels from wood-based materials is often the best solution. An alternative is to use flexible trim profiles or specially designed MDF profiles that can be bent if the slope is very irregular.
valdemar31 schrieb:
Does anyone have practical experience with the best way to handle the measurement sequence
Recommended procedure:
- Measure from the floor to the underside of the slope.
- Determine the maximum cabinet height at that point.
- Divide vertically from bottom to top and adjust the cabinet heights accordingly.
It is advisable to close gaps with narrow trim strips rather than changing the cabinet depths or heights.
Hope that helps.
