ᐅ Are there ways to adjust or modify IKEA Besta drawers to make them easier to open and close?
Created on: 24 Jan 2015 14:23
Tanner
I have a specific issue with my IKEA Besta drawers. While they generally work, they often get stuck or require significant force to open and close. I’m interested to know if there are any tested methods, tricks, or possible modifications that can make these drawers easier to operate and prevent them from sticking permanently. I am not referring to general repairs for defects, but rather a type of functional optimization or adjustment to improve handling.
Has anyone had experience with precise solutions, such as adjustments to the drawer slides, lubricants, or design improvements that can be done without much effort? I would appreciate any concrete tips or guidance on how to proceed.
Tanner
26 Jan 2015 09:22
dota57 schrieb:
An additional note: With Besta drawers, the sticking behavior can also be influenced by temperature fluctuations and material expansion.
That’s something I hadn’t considered before, thanks for pointing it out. My Besta is located in an unheated room, so temperature fluctuations could indeed be relevant.
Brian schrieb:
If you want, I can also provide tested sources for spare parts.
Yes, please, that would be very helpful if I need to order replacement parts.
One more question for everyone: Are there specific models of drawer slides or rollers that are particularly durable or less problematic? Like an upgrade that is compatible with the system?
CLINTCHEN
26 Jan 2015 10:57
Regarding your last question, Tanner:
Many users recommend rollers made of polyamide or nylon, as these are significantly more durable than basic plastic rollers and less likely to jam.
To make operation easier, you can also install retrofit soft-close mechanisms. These reduce the force needed and prevent sudden closing, which can also lead to jamming.
Precise adjustment of the tracks is always important. Even the best materials won’t help if the angle is off.
In summary:
- Replacement rollers made of nylon or polyamide
- Cleaning and lubrication with silicone spray
- Optional installation of soft-close fittings
This will noticeably improve the handling.
