ᐅ Are there connection options between the Ikea PLATSA and PAX systems?
Created on: 4 Apr 2023 08:17
TRAMU
I am currently planning a custom storage system for my bedroom and have come across a question that seems important to me: Are there any connection possibilities or compatibilities between the Ikea Platsa system and the Pax wardrobe system?
More specifically, I am interested in whether these two systems can be flexibly combined—either through suitable connectors, some kind of adapter, or other practical solutions offered by Ikea or third-party providers.
I am asking because Platsa is very versatile due to its modular design, while Pax is often considered a classic wardrobe system. Knowing whether these concepts can be sensibly combined would certainly be helpful for many when planning their room layouts.
Does anyone have experience or even creative solutions for effectively joining or connecting these two ranges?
Thanks in advance for your expertise and tips!
Jonas66
4 Apr 2023 12:27
Short answer: Officially no, there are no connection options.
If you measure very precisely, you can build something yourself using angles or screw fasteners, but that is the user’s responsibility.
parnar
4 Apr 2023 13:08
Hey, I find this topic really interesting! I tried to visually match my Platsa modules to an existing Pax wardrobe. I used wooden edge strips to compensate for the difference in depth. It looks quite good and is also stable.
You do need some DIY skills and patience, but the personalized look is really fun! So: be brave and experiment, it’s definitely worth it!
Josefane
5 Apr 2023 07:43
I have some reservations.
parnar schrieb:
I once tried to visually match my PLATSA modules to an existing PAX.
The effort is commendable, but without standardized connectors or a defined system, this could become problematic in the long run—especially regarding stability and user-friendliness.
If we are discussing solutions here, I would be interested to know whether any load tests or long-term user experiences exist for custom-made transitions.
Who can provide concrete feedback based on experience?
JAFUHAU
5 Apr 2023 08:22
Josefane schrieb:
When we discuss solutions here, I’d be interested to know what load tests or long-term user experiences exist regarding homemade transitions.
This is indeed an important point! In my case, although I don’t yet have long-term experience, many reports from forums and private messaging groups indicate that homemade solutions can last for years if handled carefully.
However, there are also cases where the connections have loosened over time or problems occurred under heavy load.
I believe the rule here is: the more stability you plan for and the more you use professional fastening materials, the better the chances for lasting performance.
Blavin
5 Apr 2023 09:38
One more factual addition: Since Ikea develops these systems independently from each other, there are no official connecting profiles.
If someone is looking for a practical recommendation on how to plan a combined system, I suggest the following:
- Compare the exact dimensions of the individual modules
- Adjust the base heights as needed, using leveling feet or shims
- Reinvest with metal connecting profiles, preferably angle adapters
- Ensure the fronts are aligned evenly to maintain both appearance and functionality
This way, a customized solution can be created without compromising functionality.
TRAMU
5 Apr 2023 10:54
Blavin schrieb:
Compare the exact dimensions of each module
Thank you, this is a very important insight for me.
JAFUHAU schrieb:
The more stability you plan for and the more you focus on professional fastening materials, the better the chances for long-lasting performance.
These tips help me a lot, as I had planned to make the connections as simple and cost-effective as possible.
By now, I think the key is to first record the exact module dimensions and then connect them securely using targeted metal brackets.
I also find the idea of wooden strips or adjustable feet for the visual and functional compensation of depth and height differences very sensible.
Does anyone perhaps have additional advice on what to consider during assembly, especially regarding the weight of the stored items?
