ᐅ Alternative to a cordless drill?
Created on: 20 Jul 2015 17:44
FBDIMM
FBDIMM
20 Jul 2015 17:44
Since I now need to make about 40 holes in my home for lamps, shelves, etc., my cordless screwdriver is not sufficient.
Unfortunately, it runs out of power after about 1 hour, and it takes me quite a bit of time to drive in each screw.
Are there any cordless screwdrivers that, for example, allow for mains power operation? Or are those impact drivers any good? I would really prefer a tool that can be plugged in, as I basically have access to electricity wherever I’m working.
Looking forward to your advice.
Umbau-Susi20 Jul 2015 17:57
2. Battery?
Musketier20 Jul 2015 17:57
How about using a drill for drilling and a cordless screwdriver for driving screws, just as originally intended?
The drill should preferably be a hammer drill.
RFR20 Jul 2015 18:44
A reliable branded tool with 2 batteries, for example in blue with 18 volts and 4.0 Ah. It is powerful and has good endurance. The second battery can be fully charged in half an hour.
It should last a DIYer’s entire lifetime.
Umbau-Susi20 Jul 2015 19:02
RFR schrieb:
A reliable branded tool with a second battery. For example, in blue with 18 volts and 4.0 Ah. It’s powerful and has good endurance. And the second battery charges in half an hour.
It should also last a lifetime for any DIY enthusiast.
Our blue one has already lasted through the entire house renovation. A second battery is all you need. Plus, the small green one in the toolbox for fiddly jobs in some corners. That way you are well equipped.
Sylvia
Payday
20 Jul 2015 20:37
A cordless drill driver for drilling holes in solid reinforced concrete walls? That’s a nightmare! Get a hammer drill with proper drill bits and then drive the screws in using the cordless drill driver.
And yes, there are cordless impact drivers, but they’re not designed to drill into thick walls. I have a Makita 18V cordless impact driver and it struggles with solid ceilings. With my dad’s corded impact drill, I can make the hole in 5 seconds. These tools aren’t that expensive either. For DIY users, for example, the green Bosch range is usually sufficient.
