I need your attention and some brainpower!
We had a wall outlet installed in the bathroom for accent lighting, connected to a light switch. The plan was to build a drywall (gypsum board) shelf along the sloped ceiling, continuing the cladding (top left in turquoise), so it flows seamlessly. Behind it, a simple LED strip would be installed to cast light evenly across the entire surface. The area is 210cm long (83 inches).
We are hesitant to implement this because of the roof slope and the joins—it will probably turn out crooked and uneven here :p
Do you have any other ideas?
Maybe there are ready-made fixtures available?
I currently have a 25% Paulmann coupon through Sovondus, but I’d rather let it expire if I can find something creative and affordable at the bookstore or elsewhere.
Badjunge schrieb:
Inside, then stick an aluminum strip from the hardware store and mount the moisture-resistant LED strip on it.Could you please explain this to me? We probably still have a drywall strip, which we set aside, but how do we fix it in place?
There are special drywall molding pieces available. They can also be installed using a special adhesive. This might be something for you.
