ᐅ 1970s attic ladder, but ceiling joist spacing is only 69 cm
Created on: 30 Dec 2024 21:21
Jens Kaufmann
Jens Kaufmann
30 Dec 2024 21:21
Good evening.
I have the opportunity to get a new attic ladder measuring 70x120cm (28x47 inches) at a good price. However, the ceiling joists at the intended installation location are only 69cm (27 inches) wide.
Would it be possible to taper both ceiling joists by about 7-8mm (0.3 inches) over a length of 120cm (47 inches), or would it be better to buy a different attic ladder, for example 60x112cm (24x44 inches)? Unfortunately, that one costs three times as much.
Peter_H_
30 Dec 2024 22:52
Are you referring to a retractable attic ladder? These are usually slightly narrower than the specified dimension, and the gap is typically filled with insulation material. Just refer to the installation manual for the exact measurements. It might fit anyway. Otherwise, you can’t make a general statement about tapering the joists. It depends on how strong they are in their original condition and what percentage you want to reduce.
hanghaus2023
31 Dec 2024 12:50
How wide are the beams?
