ᐅ Cap for removed radiator
Created on: 27 Dec 2023 15:12
Mario187
Mario187
27 Dec 2023 15:12
Hello!
I removed a radiator. Unfortunately, the drain opening has a very unusual size: an end cap with a 1-inch (25mm) diameter is slightly too small. The next size, 1 1/4 inches (32mm), is already much too large.
I just can’t find the right size, and soon I will definitely have to heat again, otherwise the pipes might burst when temperatures drop below zero.
Close-up of a pipe with a measuring tape measuring the hole diameter, wall in the background
Rusty pipe end with dark interior surface, on a rough white wall.
allstar83
28 Dec 2023 08:46
Blind caps are also available on Amazon in 3/4" size.
hanghaus2023
28 Dec 2023 09:29
If 1 inch is too small, then 3/4 inch is definitely too small.
jens.knoedel
28 Dec 2023 09:54
Mario187 schrieb:
I just can’t find the right size, and soon I’ll probably have to heat again, otherwise the pipes will freeze if it gets below zero.
1. Take a caliper and measure the exact size.
2. If step 1 shows that you actually have a size no longer available in specialty stores, simply unscrew the small threaded adapter. There will surely be a standard thread underneath.
Nida35a28 Dec 2023 10:21
jens.knoedel schrieb:
then you simply unscrew the small threaded adapter. There will probably be a standard thread underneath.
The white elbow fitting has an internal thread, and the other part is sealed with hemp fiber.
The elbow has pipe threads, for which there are cap screws available.
Mario187
29 Dec 2023 11:19
2. If step 1 results in a measurement that no longer exists in standard retail, simply unscrew the small threaded adapter. You will most likely find a standard thread underneath.
Thank you, I removed the threaded adapter and indeed found a 3/4 inch standard thread. Bought a valve, problem finally solved. Sometimes you can't see the forest for the trees. Great guy, cool community.
