ᐅ I need advice regarding the costs of a heating system.
Created on: 29 Nov 2013 19:11
KayEcb
We are planning to build an urban villa. According to the building description, it will be constructed with 17.5 cm (7 inches) calcium silicate bricks and a 14 cm (5.5 inches) external thermal insulation composite system (ETICS), with a hipped roof at a 22-degree pitch.
The ceiling height should be 2.5 m (8.2 ft) for the 138 m² (1,487 ft²) living area.
The heating system specified in the building description is a Vaillant AuroCompact with a stratified storage tank (150 liters (40 gallons)), underfloor heating on both floors with individual room controls, and 2 solar panels (each 2.51 m² (27 ft²)).
We have now inquired about the additional cost if we want to upgrade to a KfW 70 energy standard house.
The following offer was made to us:
Increase insulation thickness from 14 to 16 cm (5.5 to 6.3 inches), install an air-to-air heat pump heating system (manufacturer not yet specified), and upgrade windows to triple glazing (currently Veka with double glazing, Ug 1.0). The price is €12,500. Is this justified? I find it a bit high, especially considering that the gas connection costs have already been offset in the calculation.
Unfortunately, I don’t know the heating load.
Regards,
Kay
Bauexperte
1 Dec 2013 20:44
Nutshell schrieb:
Is it even clear what aerated concrete is? I think here Poroton (which can be filled with polystyrene beads, etc.) is being confused with aerated concrete
Maybe you should take a look at my profile once 😉 Best regards, Bauexperte
Bauexperte
1 Dec 2013 20:54
Good evening,
Nutshell schrieb:
But still, aerated concrete blocks are not filled with anything ;-)
Then that is not sufficient – just my humble opinion. There are both organic and mineral fillers.
Nutshell schrieb:
What do you think is missing to achieve KFW55? We also do not want any polystyrene on the wall, especially since, according to my "supplier," it is not necessary to reach the target.
You can use the informal form with me :-)
I already mentioned that. If your supplier says it works, they should provide you with written proof… no loopholes.
Regards, Bauexperte
Nutshell
1 Dec 2013 20:58
This has been documented in writing, after all, a KfW55 house was sold! 😉
Bauexperte
1 Dec 2013 21:40
Nutshell schrieb:
It is all documented in writing, after all, a KfW55 house was sold! 😉
Then please share – if you wish – which additional measures were taken … at your expense or that of your supplier.
Regards, Bauexperte
Nutshell
1 Dec 2013 21:47
Bauexperte schrieb:
Then please share – if you want to – which additional measures have been taken… at your cost or that of your supplier.
Regards, Bauexperte
Why do you assume that something needs to be changed in order to achieve that?
Bauexperte
1 Dec 2013 21:55
Nutshell schrieb:
Why do you assume that something needs to be changed to achieve that?
17 years of continuous learning 😉
Regards, Bauexperte
