bauherr20161527 Nov 2021 07:36Hello, I have a question about the default setting for the hysteresis. The manual shows it like this:
so 10-100 and the default is 30.
However, the system itself shows the following range:
30-1500 and mine is set to 150.
What I want to know is, what is the standard value here? It seems to me that the system has to turn on quite often at 150. What do you think?
Regards
Regards
I can’t tell you what the standard value is.
bauherr201615 schrieb:My (general) advice would be:
It seems to me that the system has to start up quite often at 150.
- Adjust the value
- Observe the effects
- Draw conclusions
- Repeat
RotorMotor27 Nov 2021 13:21What do you mean by "the feeling that the heat pump switches on frequently"?
What exactly is your concern?
